Автор Тема: 10TV044R1  (Прочитано 196 раз)
10TV044R1
« : 02 Декабря 2023, 16:03:16 »
10TV044R1
AZ-1BD_3A-BD, AZ-1L_2B-2, AZ-1L_3A-0, AZ-1L_3A-0.5, AZ-1L_3A-1,
AZ-1L_3A-2, AZ-1L_5-0 Chassis
BC
Subject IRIS
LED Flashing 7 Times [REVISION 1] 117E
• After powering on, the LED flashes 7 times, indicating a thermal error, and the TV automatically turns off.
* In the Service error menu, each time the error occurs, the “error 007” value augments by 1.
* The error may not occur right after powering on and be difficult to duplicate due to the IC deviation and because it
is time-dependent. It may need a few hours of ageing before it can be reproduced again.
• Brightness and white balance of the LCD display may slightly change because of the abnormal control data
through I2C communication.
CAUSE
Leaking RGB sensor on the H board, reducing the voltage level of the I2C communication line (SCL/SDA), which is
the same bus line as the thermal sensor.
• Before checking the Main (BAL) board, check and (if necessary) replace the H board, following the procedure
outlined below.
Description Chassis Part number
HLR Mount
AZ-1BD_3A-BD, AZ-1L_3A-1, AZ-1L_3A-2 A-1753-636-A
AZ-1L_3A-0.5 A-1759-226-A
AZ-1L_3A-0 A-1744-404-A
AZ-1L_2B-2, AZ-1L_5-0 A-1744-408-A
