Автор Тема: 10TV043  (Прочитано 205 раз)
10TV043
« : 02 Декабря 2023, 16:02:15 »
10TV043
AZ-1BD_3A-BD Chassis
AZ-1H_1A, AZ-1H_2A-2, AZ-1H_2A-3 Chassis
AZ-1L_2B-1, AZ-1L_2B-1.5, AZ-1L_2B-2, AZ-1L_3A-0, AZ-1L_3A-0.5,
AZ-1L_3A-1, AZ-1L_3A-2, AZ-1L_5-0 Chassis
BC
Subject IRIS
PC Input Detection F751
Depending on the PC cable used, the TV is not able to detect the PC input.
CAUSE
TV is using pin #5 of the PC cable to detect the PC input (low GND = OK). Some PC cables have a disconnected
pin #5.
To remedy the problem, choose between one of the options below.
 Exchange the PC cable by one with pin #5 connected, OR:
 Turn off the automatic detection by doing the following via the XMB (Cross Media Bar):
Settings => External Inputs => AV preset => PC Input => Enable => Change from “Auto” to “Always”.
