Автор Тема: 10TV039  (Прочитано 200 раз)
10TV039
« : 02 Декабря 2023, 09:33:29 »
10TV039
KDF-E42A11E, KDF-E50A11E, KDL-S23A11E, KDL-S26A11E,
KDL-S32A11E, KDL-S40A11E, KDL-V26A11E, KDL-V32A11E,
KDL-V40A11E, KDL-W40A11E
BC
Subject IRIS
Digital Channels not Stored after Power Off C762
When powering off the set with the [Power] button or mains, DVB-T services are lost.
CAUSE
The Flash file system cannot store more than 255 services.
=> Tune database software modules use an internal limit of 2000 programmes, whereas the flash memory buffer
for the above listed models allows a maximum of only 255 programmes. The tune database is not saved if the
actual file exceeds the physical file size in the flash buffer configuration. As a result, the customer can store more
than 255 services in auto tuning, but once the set is powered off by the power button or mains, the tune database
file is not stored in the flash buffer and information is lost.
NOTE: Currently, only in Italy more than 255 channels are available. Other countries have less than 100 services.
The problem can be resolved by
 Manually tuning new channels, or
 Updating the software, following the procedure outlined below.
Software Type Version Location
EMMA2L 2.11.304 PWB-N
NOTES
* In case the set is out of warranty, manual tuning is recommended.
* If you need a CAM to perform an update, contact your local service department.
Update process
1. Select a digital channel.
2. Disconnect the AC power.
3. Insert the PCMCIA card.
4. Connect the AC power.
5. An upgrade will happen as the set powers on. The screen may be blank or green for a few seconds. When the
digital banner appears, the update is completed.
6. Remove the PCMCIA card.
7. Confirm the software version.
8. Apply “TT08”.
9. Re-tune the TV.
Condition
code
Sy
