Автор Тема: 10TV037  (Прочитано 195 раз)
10TV037
« : 02 Декабря 2023, 09:32:21 »
10TV037
KDL-40HX700, KDL-40HX701, KDL-40HX703, KDL-40HX705,
KDL-46HX700, KDL-46HX703, KDL-46HX705
BC
Subject IRIS
CAUTION: Avoid Direct Sunlight 4326
In direct sunlight (shop window) overheated picture parts may darken out.
CAUSE
Under the influence of the glass plate, the temperature in the panel surface rises above 65 °C, which is out of the
panel specifications.
 The set will fully recover after the screen temperature turns back to normal.
 Install the TV in an area without direct sunlight, and follow the caution notes included in the TV Instruction
Manual to avoid high temperature environments in the future.
