Автор Тема: 10TV035R1  (Прочитано 206 раз)
10TV035R1
« : 02 Декабря 2023, 09:28:07 »
10TV035R1
AZ-1H_2A-2, AZ-1H_2A-3 Chassis,
KDL-40EX700, KDL-40EX701, KDL-40EX703, KDL-40EX705,
KDL-40EX706, KDL-40EX707, KDL-40EX708, KDL-40EX709,
KDL-46EX700, KDL-46EX701, KDL-46EX703, KDL-46EX705,
KDL-46EX706, KDL-46EX707, KDL-46EX708, KDL-46EX709
BC
Subject IRIS
Continuous Clicking Noise after Powering Off [REVISION 1] P147
A clicking/ticking noise may be audible continuously from the rear side of the set, especially the first hour after
powering off or when powering on from the cold.
CAUSE
Mechanical contraction/expansion of panel parts.
In case of a customer complaint, replace the panel. Repair panels have the same part number as the original one
(please refer to the Service Manual), but the countermeasure has by default been applied.
NOTE: For correct handling, please clearly mention the symptom and reference number as indicated below.
