Автор Тема: 10TV055  (Прочитано 398 раз)
10TV055
« : 02 Декабря 2023, 09:25:52 »
10TV055
KDL-32BX300 BC
Subject IRIS
EDID Rewriting for WXGA Resolution F311
In HDMI and PC input with specific source equipment, the FHD instead of the native WXGA panel resolution is
shown. WXGA can still be selected manually.
CAUSE
FHD EDID written on WXGA models in production.
1. Take an empty USB Stick and update the EDID with the special UPG file attached to this Technical Bulletin,
following the procedure described in TB 10TV007.
Date File
July 2010 WXGA_EDID_PKG_M8R515.upg
2. Wait 2 minutes for safety.
3. Reset the TV.
4. Perform a regular software update with the latest SW package available (SecureDev_ProdCred_M*_M*.upg),
which is attached to TB 10TV005, referring to TB 10TV007 for the update procedure.
5. Reset the TV.
APPLICABLE SERIAL NUMBERS
Destination Serial number
AEP/UK 2500001~2513447
10TV055 - EDID Rewriting for WXGA Resolution - KDL-32BX300
