Автор Тема: 10TV030R3  (Прочитано 214 раз)
10TV030R3
« : 02 Декабря 2023, 09:21:34 »
10TV030R3
KDL-26EX301, KDL-26EX302, KDL-32BX400, KDL-32EX401,
KDL-32EX402, KDL-32NX500, KDL-37EX401, KDL-37EX402,
KDL-37EX403, KDL-37EX500, KDL-37EX503, KDL-37EX504,
KDL-37EX505, KLV-26BX300, KLV-26BX301, KLV-26NX400,
KLV-32NX500
BC
Subject IRIS
Buzz Noise [REVISION 3] 1144
An audible squeal noise may come from the Inverter board, especially at low speaker volume level. The sound may
slightly change depending on the selected picture mode.
CAUSE
In the Inverter board, a lack of RTV between core and bobbin causes a gap which provokes the noise. Based on a
visual inspection of these transformers, RTV was not properly applied although the quantity might be enough.
Replace the defective Inverter board.
Model
PANEL INVERTER MT BOARD
Part number Label Part number Label
26” 1-811-071-11 T260XW05V0 1-857-693-11 1926T06001
32” 1-811-073-11 T315HW04V0 1-857-735-11 1931T09001
37”
1-811-074-11 T370HW03V8 1-857-701-11 1937T05007
1-811-077-11 T370HW03V9 1-857-701-11 1937T05007
