Автор Тема: 10TV029  (Прочитано 205 раз)
10TV029
« : 02 Декабря 2023, 09:18:23 »
10TV029
AZ-1L_2B-2, AZ-1L_3A-0, AZ-1L_3A-1, AZ-1L_3A-2,
AZ-1L_5-0 Chassis
BC
Subject IRIS
No Picture / Sound 6310
In rare cases, there is no picture and sound when powering on, and no Power LED diagnosis indication.
CAUSE
EMMA S/W stop progress of the Power On sequence, due to the initial control for the One-NAND device by
EMMA3TL S/W.
Proceed as indicated below.
1. Confirm that there is no picture and sound.
2. Confirm that there is no LED diagnosis.
3. Check the Power supply. The voltage at pin 1 of CN3800 on the BAL board must be 3.3 V.
=> ONLY if the three conditions above are simultaneously fulfilled, change the BAL board.
Description Model Part number
BAL board
EX500, 501; HX700, 701 A-1760-331-A
EX700, 701 A-1763-466-A
EX705, 706, 707, 708, 709 A-1763-467-A
EX703 A-1763-468-A
EX503; HX703 A-1768-994-A
EX505, 508; HX705 A-1769-581-A
EX403 A-1769-676-A
NX503 A-1780-318-A
EX504 A-1780-319-A
