Автор Тема: 10TV017  (Прочитано 191 раз)
10TV017
« : 02 Декабря 2023, 07:48:53 »
10TV017
AZ-1H_2A-2, AZ-1H_2A-3
AZ-1L_2B-1, AZ-1L_2B-1.5, AZ-1L_2B-2, AZ-1L_3A-0.5, AZ-1L_3A-1,
AZ-1L_3A-2,
AZ-1N_3A-2, AZ-1N_5-0, AZ-1N_5-2 Chassis
BC
Subject IRIS
Mounting Hook on VESA Bracket Screwing Problem 1654
It is not possible to fix the wall mounting hooks to the rear cover.
CAUSE
Either the internal nut holder is broken, or the internal nut is loose due to screws longer than 16 mm being used.
If necessary, replace the rear cover. Make sure to use the correct screw size, which is maximally 12 mm in length
measured from the attaching surface of the mounting hooks. Otherwise, the TV may be damaged again.
Model Description Part number
SU-WL500, 50B, 700 +PSW 6x16 2-580-611-01
