Автор Тема: 10TV015  (Прочитано 197 раз)
10TV015
« : 02 Декабря 2023, 07:45:59 »
10TV015
KDL-32P3600, KDL-37P3600, KDL-40P3600 BC
Subject IRIS
Blurry Picture after Software Upgrade C33X
After updating to software package #22 using a USB stick, the picture may become blurry.
CAUSE
Unmasked byte in the NVM.
If the symptom occurs, perform a factory reset, as outlined below.
1. Enter the User Menu using the remote commander.
2. Select “Settings” and press [OK].
3. Go to the “Set-Up” menu. The below sub-menu will appear.
