Автор Тема: 10TV013  (Прочитано 216 раз)
10TV013
« : 02 Декабря 2023, 00:59:38 »
10TV013
KDL-37V5500, KDL-37V5610, KDL-37V5800, KDL-37V5810 TD
Subject IRIS
Caution when Replacing LCD Panel
Two types of LCD panel can be used, being compatible after a software upgrade.
Description Part number Label
LCD Panel (A) 1-802-884-11 T370HW02VB
LCD Panel (B) 1-811-007-11 T370HW03V3
When replacing to panel B in case panel A was originally installed, it is recommended to update to PKG #1570 or
higher, which is attached to Technical Bulletin 09TV040, otherwise “Error 6” (inverter error) may occur.
