Автор Тема: 10TV009R4  (Прочитано 196 раз)
10TV009R4
« : 02 Декабря 2023, 00:57:31 »
10TV009R4
T-con 2009 Models BC
Subject IRIS
T-Con Board Replacement [REVISION 4]
The T-con board for the listed models has been registered for service.
 In case of any of the below symptoms, do not exchange the entire panel, but simply replace the T-con board
according to the part number info on the next pages.
 If the problem remains after T-con board replacement, proceed with the entire LCD Panel replacement.
*Reference: Fill in the individual RMA ID generated by the Module Exchange Reporting tool.
Symptom Detail IRIS code
Abnormal Display
Gamma Problem 1320
Lines in Picture 1386
WB Problem
132X
Colour Fail
Half Picture 1327
Double Picture 1340
No Display Backlight On 1310
Picture Noise Interference Noise 1340
Mechanical Problem
Broken Board
113X
FFC Fail
Line Defect
Data Block Defect
1389
Data Line Defect
Condition
code
Symptom
code
Part
number Ref. Section
code PCB Defect
code
Repair
code Qty.
1 cf. above cf. table RMA ID* LCD T-con N A 1
2 / 4 10TV009R4
Model S-LCD Panel T-con board
Part number Label Rev. Part number Label
KDL-32P3500
KDL-32P5500
KDL-32S5500
KLV-32S550A
1-802-932-31
1-802-932-32
1-802-932-33
1-802-932-34
LTY[Z]320AP01
003
004
005
105 1-857-559-12 LJ94-02832L
1-802-932-71 LTY320AP03 A03
1-802-932-91 LTY320AP02 007
KLV-32S550A 1-802-807-11 V315B3 L01 / /
KDL-32P3600
KDL-32P56xx
KDL-32S56xx
KDL-32V5500
KDL-32V5610
KDL-32V58xx
KLV-32V550A
1-802-931-11
1-802-931-21 LTY[Z]320HA03 A01 / A02 1-857-521-11 LJ94-02833C
KDL-32V5500
KDL-32V5610
KDL-32V58xx
1-802-801-11
LTY[Z]320HA02
001 1-857-041-12 LJ94-02217H
1-802-801-12 002 1-857-041-13 LJ94-02217J
KDL-40E55xx
KDL-40W5500
KDL-40W57xx
KDL-40W58xx
1-802-877-11
1-802-877-12
1-802-877-13
LTY[Z]400HF05 001 / 002/ 003 1-857-374-11 LJ94-02782B
1-802-877-21 LTY[Z]400HF05 A02 1-857-538-11 LJ94-02932B
KDL-40WE5
1-802-874-11 LTY[Z]400HF02 001
1-802-874-21 1-857-392-11 LJ94-02645E
1-802-874-22
1-802-874-23
LTY[Z]400HF02 102 / 203 / 204
KDL-40Z5500
KDL-40Z5710
KDL-40Z58xx
1-802-897-11
1-802-897-12 LTY400HG02 001 / 101 A-1653-702-A LJ94-02693A
1-811-018-11 LTY[Z]400HG02 203 A-1734-930-A /
KDL-40P3600
KDL-40P5500
KDL-40P56xx
KDL-40S5500
KDL-40S56xx
KDL-40V5500
KDL-40V5600
KDL-40V58xx
KLV-40V550A
1-802-930-21
1-802-930-22 LTY[Z]400HA12 A0(x) 1-857-522-11 LJ94-02814D
KDL-40P3600
KDL-40P5500
KDL-40P56xx
KDL-40S5500
KDL-40S56xx
KDL-40V5500
KDL-40V5600
KDL-40V58xx
1-802-800-11 LTY[Z]400HA11 001
1-857-238-21
1-857-238-22
1-857-238-23
LJ94-02441F
LJ94-02441J
LJ94-02441L
10TV009R4 3 / 4
IMPORTANT: For KDL-46W*, the 1-857-375-11 and 1-857-561-xx T-con board may not be available.
 An alternative T-con board can be ordered instead.
Original T-con Alternative T-con
1-857-375-11
1-857-574-11
1-857-561-21
 If using an alternative T-con board, 3 gaskets must be ordered in addition. Please refer to the below picture for
their exact adhering position.
Description Part number Note
Gasket
4-159-550-01 Long (1 piece)
4-159-551-01 Short (Please order 2 pieces)
KDL-46W5500
KDL-46W57xx
KDL-46W58xx
1-802-876-11 LTY460HF05 001 / 002 / 003 1-857-375-11 LJ94-02642J
1-802-876-12 LTY460HF05 004 1-857-574-11 LJ94-02937H
1-802-876-21 LTY460HF06 A01 1-857-561-11 LJ94-02937E
1-802-876-31 LTY460HF07 001 1-857-561-21 LJ94-02642P
1-802-876-32 LTY460HF07 002 1-857-574-11 LJ94-02937H
1-802-876-41 LTY460HF07 A01 1-857-561-11 LJ94-02937E
KDL-46WE5
1-802-873-11 LTY[Z]460HF03 001 / 002 / 003
1-857-572-11 LJ94-02642H
1-802-873-21 LTY[Z]460HF03 102 / 103
1-802-873-22 LTY[Z]460HF03 104 1-857-573-11 LJ94-02937J
KDL-46V5500
KDL-46V5610
KDL-46V5800
KDL-46V5810
1-802-929-11
1-802-929-21 LTY[Z]460HB11 A0(x) 1-857-523-11 LJ94-02811D
KDL-46Z5500
KDL-46Z5800
1-802-896-11
1-802-896-12
1-802-896-13
LTY460HG02 001 / 101 / 102 A-1653-703-A LJ94-02704A
1-811-017-11
1-811-017-12 LTY460HQ01 001 / 002 A-1734-931-A LJ94-03131A
KDL-52Z5500
KDL-52Z5800
1-802-895-11
1-802-895-12 LTY520HH02 001 / 002 A-1653-704-A LJ94-02695A
1-811-016-11 LTY520HQ01 001 A-1734-932-A LJ94-03127A
KDL-52W5500
KDL-52W5800
1-802-875-11
1-802-875-12 LTY520HE12 001 / 002 / 003
1-857-376-12 LJ94-02638L
1-802-875-13 LTY520HE12 004
KDL-52V5500
KDL-52V5610
KDL-52V5800
KDL-52V5810
1-802-933-11 LTY[Z]520HB11 001 1-857-524-11 LJ94-02871D
4 / 4 10TV009R4
Model AUO Panel T-con board
Part number Label Part number Label
KDL-32E55xx
KDL-32W5500
KDL-32W57xx
KDL-32W58xx
1-802-886-11 T315HW02-V1 1-857-405-11 55.31T06.C01
KLV-37S550A 1-802-864-11 T370XW02-VC02 1-857-450-11 55.37T03.C14
KDL-37P3600
KDL-37P5500
KDL-37P56xx
KDL-37S5500
KDL-37S56xx
KDL-37V5500
KDL-37V5610
KDL-37V58xx
1-802-884-11
1-811-007-11
T370HW02-VB
T370HW03-V3
1-857-406-11
1-857-726-11
55.37T04.C29
55.37T05.C08
KDL-37W5500
KDL-37W57xx
KDL-37W58xx
1-802-885-11 T370HW02-VD 1-857-407-11 55.37T04.C24
1-802-996-11 T370HW02-V4 1-857-728-11 55.37T05.C07
KLV-46V550A 1-802-880-11 T460HW03-V2 1-857-408-11 55.46T03.C08
