Автор Тема: 10TV001R1  (Прочитано 185 раз)
10TV001R1
« : 02 Декабря 2023, 00:53:06 »
10TV001R1
KDL-40Z5800, KDL-40Z5810, KDL-46Z5800, KDL-52Z5800 BC
Subject IRIS
EX2L_Paprika_Sat Panel Replacement Caution Notes [REVISION 1]
Two types of panel exist, being compatible after a software / NVM update.
1. Panel identification
Use the panel label and/or serial number to identify the panel type.
ORIGINAL panel NEW panel (QDL)
Label Part number Serial
number Label Part number Serial
number
40” LTY(Z)400HG02<200 1-802-897-12
9000001~
9300001~
LTY(Z)400HG02≥201 1-811-018-11
9200001~
9100001~ 9500001~
9400001~
46” LTY(Z)460HG02 1-802-896-13 9000001~
9300001~ LTY(Z)460HQ01 1-811-017-11 9100001~
9400001~
52” LTY(Z)520HH02 1-802-895-12 9000001~
9300001~ LTY(Z)520HQ01 1-811-016-11 9100001~
9400001~
2. Software update
In case of exchanging to a different panel type, make sure to install the updates indicated below, using the software
attached to Technical Bulletin 09TV093.
2-1. Make sure SW version #1.585 or higher is installed, using the “MSImage_*.zip” file.
2-2. Make sure that the NVM is compatible.
Original panel New panel
Paprika_SAT_40/46/52SLCD_SiTu.zip Paprika_SAT_40/46/52SLCD_SiTu-QDL.zip
