Автор Тема: 10TV047R7  (Прочитано 379 раз)
10TV047R7
« : 02 Декабря 2023, 00:51:36 »
10TV047R7
PROACTIVE / REACTIVE 2 BC
Models
AZ-1BK_5-3, AZ-1BK_5-3D Chassis
Subject: Software Packages Follow-Up for AZ-1BK Chassis [REVISION 7]
The latest software package is valid for the listed models of the AZ-1BK Chassis. Amongst others, it can be used to
resolve the issues mentioned below.
Issue TB Rev.
Multi brand panel compatibility 10TV020 R0
IRIS code
DK Channel table fine-tuning problem
* Fine-tuning value is not correct for Russia (System DK, Channel S01) and other
countries (System DK, Channels S01-S10).
C262
R0
Analogue manual tuning decrease problem after S21 channel (Russia)
* Tuning with left key jumps from S21 to S09. C261
[Arrow] key does not work correctly in Teletext subpages 117C R2
Sleep Timer does not work with subtitles 1172 R4
No sound by headphones when audio description is set on (ALL but Italy) G517
R6
Wrong picture format after program change (ALL but Italy) 2336
Condition
code
Symptom
code
Part
number Ref. Section
code PCB Defect
code
Repair
code Qty.
Proactive x xxx 10TV047 SFT 1 2
Reactive x xxx 10TV047 xxx 1 3
2 / 3 10TV047 R7
Download (and unzip) the attached file(s) in order to install the applicable software, referring to the next page of this
Technical Bulletin for the abridged upgrade procedure or TB 10TV046 for the full procedure.
NOTE: Please be aware that two software versions exist: one for Italy (having ITALY in the file name) and one for
all other destinations. Make sure not to mix up both versions.
Date Attachment Remark
May 2011
USER_UP_NORMAL_V04_T02_v2.zip
Application SW KDL-19/22BX200
USER_UP_NORMAL_ITALY_V00_T07.zip
USER_UP_COMBO_V04_T02_v2.zip
Application SW KDL-22BX20D
USER_UP_COMBO_ITALY_V00_T07.zip
EEP_19_AU01_v01.004.zip EEPROM file 19” AU01 panel
EEP_19_LP06_v01.003.zip EEPROM file 19” LP06 panel
EEP_19_SS01_v01.006.zip EEPROM file 19” SS01 panel
EEP_19_SS03_v01.003.zip EEPROM file 19” SS03 panel
EEP_22_AU02_v01.003.zip EEPROM file 22” AU02 panel
EEP_22_SS02_v01.004.zip EEPROM file 22” SS02 panel
EEP_22_SS03_v01.004.zip EEPROM file 22” SS03 panel
EEP_22_SS04_v01.004.zip EEPROM file 22” SS04 panel
GP_V66_GroupC.bin DVD Loader software Group C
GP_V79_GroupE.bin DVD Loader software Group E
ZIP attachment details
Attachment File
USER_UP_*.zip AP.bin
EEP_19_AU01_v01.004.zip PANEL.T5.185AU01.S.W.-.V01.004.00.bin
EEP_19_LP06_v01.003.zip PANEL.T5.185LP06.S.W.-.V01.003.00.bin
EEP_19_SS01_v01.006.zip PANEL.T5.185SS01.S.W.-.V01.006.00.bin
EEP_19_SS03_v01.003.zip PANEL.T5.185SS03.S.W.-.V01.003.00.bin
EEP_22_AU02_v01.003.zip PANEL.T5.216AU02.S.W.-.V01.003.00.bin
EEP_22_SS02_v01.004.zip PANEL.T5.216SS02.S.W.-.V01.004.00.bin
EEP_22_SS03_v01.004.zip PANEL.T5.216SS03.S.W.-.V01.004.00.bin
EEP_22_SS04_v01.001.zip PANEL.T5.216SS04.S.W.-.V01.001.00.bin
Update procedure
 1. TV
1-1. Extract the appropriate Application SW file (“USER_UP_*.zip”), and copy the included “AP.bin” file to the root
folder of your USB Stick.
NOTE: Two software versions exist: one for Italy, the other one for the rest of Europe.
1-2. Plug in the USB Stick.
1-3. Plug the AC Cord.
1-4. The update will automatically start. Wait until the message “Please remove the USB device and wait for
rebooting” appears.
1-5. Remove the USB Stick from the memory slot. The TV will reboot by itself.
10TV047 - Software Packages Follow-Up for AZ-1BK Chassis [REVISION 7]
