Автор Тема: 10TV028R3  (Прочитано 363 раз)
10TV028R3
« : 02 Декабря 2023, 00:46:55 »
10TV028R3
REACTIVE 1721 2 TD
Models
AZ-1BD Chassis
AZ1H_1A, _2A-2, _2A-3 Chassis
AZ1L_2B-1, _2B-1.5, _2B-2, _3A-0, _3A-0.3, 3A-0.5, _3A-1, _3A-2, _5-0 Chassis
Subject: Serial Number / Model Name Writing Support [REVISION 3]
No serial number and model name appear after board exchange.
CAUSE
Generic serial number for service.
Write the applicable serial number to the NVM by TL3 jig. The serial number address in the NVM consists of
7 bytes in hexadecimal format depending on the chassis.
1. Download and unpack the "CODE_AZ1LH.zip" file attached to this TB, and run the included “Code2.exe” file.
2. Make sure that the COM port baud rate is set to “115200”.
3. Open the "Analyzer" window via [MENU] => [TOOLS] => [ANALYZER], and check the [Add Check Sum] box.
10TV028 - AZ-1x - Serial Number  Model Name Writing Support [REVISION 3]
