Автор Тема: 10TV020R5  (Прочитано 405 раз)
10TV020R5
« : 02 Декабря 2023, 00:35:50 »
10TV020R5
AZ-1BD, AZ-1L_2B-1, AZ-1L_2B-1.5, AZ-1L_2B-2, AZ-1L_3A-0,
AZ-1L_3A-0.3, AZ-1L_3A-0.5, AZ-1L_3A-1, AZ-1L_3A-2, AZ-1L_5-0
Chassis
TD
Subject IRIS
Software Upgrade Procedure for AZ-1L Chassis [REVISION 5]
This Technical Bulletin describes the upgrade procedure for the AZ-1L chassis, using a USB stick. An update is
needed for software fixes, or after replacing the LCD panel or BAL board.
Chassis Description Part number
2B-1
2B-1.5
BAL Board AEP A-1778-484-A
BAL Board AEP-S A-1778-735-A
BAL Board UK A-1778-721-A
2B-2
BAL Board AEP A-1760-331-A
BAL Board AEP-S A-1769-581-A
BAL Board UK A-1768-994-A
3A-BD
BAL Board AEP A-1772-836-A
BAL Board UK A-1772-837-A
3A-0
3A-0.3
BAL Board AEP A-1763-466-A
BAL Board AEP-S A-1763-467-A
BAL Board UK A-1763-468-A
3A-0.5
BAL Board AEP-S A-1771-979-A
BAL Board UK A-1771-980-A
3A-1
BAL Board Italy A-1780-319-A
3A-1 Hotel
BAL Board AEP A-1796-761-A
BAL Board UK A-1796-762-A
3A-2 BAL Board UK A-1769-676-A
5-0 BAL Board UK A-1780-318-A
IMPORTANT: After a BAL board or panel exchange, no picture appears anymore, while the amber and green LED
are blinking. This is normal. Please proceed as indicated below.
PREPARATION
 Unzip the applicable software file(s) attached to Technical Bulletin 10TV021.
 A folder “SONY_dtv*” will be created automatically. Copy this entire folder to a USB stick.
NOTE: It is allowed to copy SW files for different segments to the same USB stick for future use.
10TV020 - Software Upgrade Procedure for AZ-1L Chassis [REVISION 5]
