Автор Тема: 10TV019R2  (Прочитано 514 раз)
10TV019R2
« : 02 Декабря 2023, 00:33:31 »
10TV019R2
AZ-1H_1A, AZ-1H_2A-1.5, AZ-1H_2A-2, AZ-1H_2A-2.5,
AZ-1H_2A-3 Chassis
TD
Subject IRIS
Software Upgrading Procedure for AZ-1H Chassis [REVISION 2]
This Technical Bulletin describes the upgrading procedure for the AZ-1H chassis, using a USB stick. An update is
needed for software fixes, or after replacing the LCD panel or BEHS board.
Chassis BEHS Board destination Part number
1A
AEP A-1783-050-A
UK A-1783-459-A
Italy A-1783-556-A
AEP-S A-1783-464-A
2A-2, 2A-3
AEP A-1766-469-B
UK A-1770-313-B
AEP-S A-1769-011-B
2A-1.5, 2A-2.5
AEP A-1788-128-A
UK A-1788-129-A
AEP-S A-1788-130-A
IMPORTANT: After a BEHS board or panel exchange, no picture appears anymore, while the amber and green
LED are blinking. This is normal. Please proceed as indicated below.
PREPARATION
 Unzip the applicable software file(s) attached to Technical Bulletin 10TV021.
 A folder “SONY_dtv*” will be created automatically. Copy this entire folder to a USB stick.
NOTE: It is allowed to copy SW files for different segments to the same USB stick for future use.
PROCEDURE
IMPORTANT
Board or Panel Exchange => Perform ALL steps of the below procedure.
(Skip step 3 in case the model is not applicable)
Regular software Update => Only perform steps 1 and 5.
1. SW upgrade
1-1. Make sure the TV is powered OFF.
1-2. Remove all cables (RF, External input, Ethernet etcetera).
1-3. Insert the USB stick to the TV.
1-4. Power ON the TV. The software upgrade starts automatically.
1-5. When the upgrade process has started, the TV goes in Standby mode
after 1 minute. The Standby LED will then be ON and the TIMER LED will blink.
Never remove the USB stick while upgrading.
1-6. After the upgrading has finished, the power turns ON automatically.
10TV019 - Software Upgrading Procedure for AZ-1H Chassis [REVISION 2]
