Автор Тема: 10TV006  (Прочитано 375 раз)
10TV006
« : 02 Декабря 2023, 00:25:42 »
10TV006
KLV-26S550A, KLV-32S550A, KLV-37S550A BC
Subject IRIS
Flashing and Jittering Picture C353
When watching certain channels in RF mode, the picture may be flashing and jittering intermittently.
CAUSE
Abnormal signal condition – the problem channel has a wider H-sync width compared to the SECAM standard
signal (difference up to 1,2 μs).
Update the firmware to the latest version, using the software files attached to this Technical Bulletin and following
the procedure described in TB 10TV008.
NOTE: In case of a 32 inch panel, first check the panel type before updating, referring to TB 09TV100 for further
details.
Panel Attachment
26S 26inch_TM3173_TD5173.C09
32S - CMO 32inch_TM3173_TD5173_CMO.C09
32S - AUO VL 32inch_TM3173_TD5173_AUO08.C09
32S - AUO VT 32inch_TM3173_TD5173_AUO09.C09
32S - SLCD HC 32inch_TM3173_TD5173_SLCD08.C09
32S - SLCD NC 32inch_TM3173_TD5173_SLCD09.C09
37S 37inch_TM3173_TD5173.C09
Condition
code
Symptom
code
Part
number Ref. Section
code
10TV006 - Flashing and Jittering Picture - KLV-26S550A, KLV-32S550A, KLV-37S550A
