Автор Тема: 10TV005R15  (Прочитано 369 раз)
10TV005R15
« : 02 Декабря 2023, 00:23:48 »
10TV005R15
AZ-1N_3A-0.5, 3A-2, 5-0, 5-2 Chassis
Subject: Software Packages Follow-Up for AZ-1N Chassis [REVISION 15]
Download and install the attached software package #38.
Date Attachment Remark
December 2011
SecureProd_ProdCred_M8R728_M8.728.upg
Software versions
SW M8.728
NVM N8.030
Standby: S10.5100
Upgrader: U8.052
SecureNVM_M8R728_BX_00_SP0.upg For BX300, 400
SecureNVM_M8R728_EX_01_SP0.upg For EX301, 401
SecureNVM_M8R728_EX_02_SP0.upg For EX302, 402
SecureNVM_M8R728_EX600_SP0.upg For EX600
SecureNVM_M8R728_NX500_SP0.upg For NX500
firmwarem3f.upg Recovery file 32/40EX600
1. Regular SW Update
Follow the abridged software update procedure below.
NOTE: TB 10TV007 contains the full upgrade procedure.
1-1. Take an empty USB stick and create a folder called “upgrades”.
1-2. Copy the “SecureDev_ProdCred*.upg” file to this folder.
1-3. Insert the USB stick in the USB TV slot, and switch on the TV. If the TV goes in Standby due to Auto panel
detect function, switch on the TV again.
1-4. Open the Service Menu and select “Software Upgrade”.
1-5. Select the “SecureDev_ProdCred_*.upg” file. Press [OK].
1-6. The upgrade process starts and takes about 3 minutes. Wait until the software download menu reappears.
1-7. Remove the USB stick, and unplug the TV for 5 minutes. If neglecting this 5 minute rest time, the Standby
micro will not be updated correctly.
2. Board/Panel Exchange
Refer to Technical Bulletin 10TV007 for the full upgrade procedure.
10TV005 - Software Packages Follow-Up for AZ-1N Chassis [REVISION 15]
