Автор Тема: 10TV002  (Прочитано 385 раз)
10TV002
« : 02 Декабря 2023, 00:18:42 »
10TV002
XEL-1 TD
Subject IRIS
Serial Number Writing 1721
No serial number and model name after board exchange.
CAUSE
Generic serial number for service.
Write the applicable serial number to the NVM by the BE jig and TL3 jig. The serial number address in the NVM
consists of 4 bytes in hexadecimal format.
1. Download and unzip the "Code2_XEL1.zip" file attached to this Technical Bulletin, and run the “Code2.exe” file.
2. Make sure that the COM port baud rate is set to "38400”.
3. Open the "Analyzer" window ([MENU] => [TOOLS] => [ANALYZER]), and check the [Add Check Sum] box.
Condition
code
Symptom
code
Part
number
Ref. Section
code
PCB Defect
code
Repair
code
Qty.
1 721 10TV002 SFT 13 2 1
2 / 2 10TV002
4. Calculate the hexadecimal code based on the serial number, for example using the Windows scientific
calculator. Enter the serial number (e.g. 4000001) and select [Hex] to have it converted to the hexadecimal code
(“3D 09 01” in the example).
Description Part number Convert to TV reply Remark
TL3 Cable Modified 9-948-600-17 HEX 50 00 06 00 00 56 Refer to TB 08TV070
5. In the [Send Command] box enter “F3 00 11 01 00 00 00 00 00 00 00 1A 00 3D 09 01”, and press [SEND].
10TV002 - XEL-1 - Serial Number Writing
