Автор Тема: 09TV121R3  (Прочитано 184 раз)
09TV121R3
« : 02 Декабря 2023, 00:14:53 »
09TV121R3
KDL-40Z5500, KDL-40Z5710, KDL-46Z5500, KDL-52Z5500 BC
Subject IRIS
EX2L_Paprika Panel Replacement Caution Notes [REVISION 3]
Two types of panel exist, being compatible after a software / NVM update.
1. Panel identification
Use the panel label and/or serial number to identify the panel type.
ORIGINAL panel NEW panel (QDL)
Label Part number Serial
number Label Part number Serial
number
40”
LTY(Z)400HG02xxx
Revision code =
001, 101 or 102
1-802-897-11
1-802-897-12
1-802-897-13
9000001~
9300001~ LTY(Z)400HG02xxx
Revision code = 203
1-811-018-11
9200001~
9100001~ 9500001~
9400001~
46” LTY(Z)460HG02 1-802-896-13 9000001~
9300001~ LTY(Z)460HQ01 1-811-017-11 9100001~
9400001~
52” LTY(Z)520HH02 1-802-895-12 9000001~
9300001~ LTY(Z)520HQ01 1-811-016-11 9100001~
9400001~
2. Software update
In case of exchanging to a different panel type, make sure to install the updates indicated below, following the
procedure outlined in Technical Bulletin 09TV025 using the software attached to TB 09TV040.
• Make sure that the NVM is compatible.
• Make sure SW version #1.600 or higher is installed, using the “MSImage_*.zip” file.
Original panel New panel
Paprika_40/46/52SLCD_SiTu.zip Paprika_40/46/52SLCD_SiTu_QDL.zip
