Автор Тема: 09TV102R1  (Прочитано 211 раз)
09TV102R1
« : 02 Декабря 2023, 00:10:31 »
09TV102R1
KDL-32D3000, KDL-32D3010 BC
Subject IRIS
Vertical Lines [REVISION 1] 138A
Vertical lines may appear, as in the examples below.
CAUSE
Sulfuration of a chip resistor electrode on the rear side of the T-con board.
Confirm the panel and replace the T-con board, following the guidelines below.
Description Part number Label / Remark
LCD Panel 1-802-411-11
1-802-411-12
LTY[Z]320WH-LH2
T-con Board 1-789-796-12 Part subject to Module Exchange Reporting
1. Take off the 4 screws of the T-con.
