Автор Тема: 09TV101  (Прочитано 186 раз)
09TV101
« : 02 Декабря 2023, 00:09:27 »
09TV101
KLV-32S550A BC
Subject IRIS
Sub Colour Adjustment after Panel / BT Main Board Replacement
After replacing the panel or BT Main board, the picture becomes greenish at Component and PC input, as below.
CAUSE
Due to the use of different panel types, the ADC calibration result hugely fluctuates. As a consequence, the current
average data cannot be used.
After exchanging the panel or main board and having updated the software to the latest version (refer to TB
09TV100 for further details), manually conduct the ADC calibration process, proceeding as indicated below.
1. Perform the “Factory Setting” and select “Shop Mode” from the initial setup menu.
2. Change to component input mode and turn off the OSD.
3. Enter “Service Mode”.
