Автор Тема: 09TV097  (Прочитано 232 раз)
09TV097
« : 01 Декабря 2023, 23:44:16 »
09TV097
EX-2L_Basil_Sat, EX-2L_Coriander_Sat, EX-2L_Paprika_Sat Chassis TD
Subject IRIS
Software / Board Exchange Upgrade Procedure for EX-2L_Satellite Chassis
This document describes the software upgrading procedure for the EX-2L_*_Sat chassis, using a Memory Stick.
• Regular Software Update => Procedure 1
• Board Exchange Update => Procedure 2
Memory Stick Preparation
* Remove unnecessary files from the MS before copying data.
* Use a Memory Stick formatter (Windows formatters are not supported). Sony format programs can be obtained
from http://www.sonydigital-link.com/memstick/downloads/downloads_ms.asp?l=en&f=MSFRM.
* Choose “Full” format (not “Quick” format).
* The flash size should be 32MB or higher.
* Preferably use a Sony device. A steady performance of products of other brands is not guaranteed.
* The file written to the MS is a ‘Memstick.ind’ file.
1. Regular Software Update
For software fixes, follow the procedure outlined in step 2-2 (“MS DL SW Update”) of this document.
IMPORTANT: Make sure to use file “MSImage_EX2L_PKGxxxSA_BCN_VC_SIGN.zip” instead of the one
mentioned in 2-2. It is not needed to execute step 2-1 first and step 2-3 afterwards.
2. Board Exchange Update
Model Part number BA Board
EX-2L_Basil_Sat A-1743-179-A
EX-2L_Coriander_Sat A-1742-450-A
EX-2L_Paprika_Sat A-1743-180-A
2-1. MS DL EMMA NVM Update
2-1-1. Extract the appropriate “Basil/Coriander/Paprika_*.zip” file attached to Technical Bulletin 09TV093.
