Автор Тема: 09TV088R1  (Прочитано 181 раз)
09TV088R1
« : 01 Декабря 2023, 23:29:03 »
09TV088R1
KDL-26V4500, KDL-26V4710, KDL-32V4500, KDL-32V4710,
KDL-32V4720, KDL-32V4730, KDL-37V4500, KDL-37V4710
BC
Subject IRIS
Caution when Replacing EG-1L Panel – V Series [REVISION 1]
Different panel types exist, being incompatible to each other.
• Always try to order the same type of panel as the one used in the set.
• If your panel type is out of stock, another one can be ordered. Since only compatible parts must be used, in
that case also the Inverter Harness or LVDS Harness has to be replaced.
• For the 32V model, a special Service Panel has been released.
1. Identify the panel type by the TV serial number and/or panel label.
Model
TV serial number Panel part number + label
Original panel VE panel Original panel VE panel
26V4500
9000001~9090001 9100001~9190001
1-802-613-11
xT260XW02VLx
1-802-754-11
xT260XW02VMx
9300001~9390001 9400001~9490001
9600001~9690001 9700001~9790001
26V4710 9300001~9390001 9400001~9490001
32V4500
9000001~9090001 9100001~9190001 1-802-649-11, -12
1-802-649-13, -14
xLTZ320AA01-xxxx
1-802-803-21, -22
xLTZ320AA03-A01x
32V47x0 9300001~9390001 9400001~9490001
37V4500
1-802-622-11
xT370XW02VEx
1-802-753-11
xT370XW02VCx
37V4710 9300001~9390001 9400001~9490001
Note for 32V Panel
Upon depletion of present stock,
please order the Service Panel indicated below.
32V Service panel
Part number Label
1-802-932-91 xLTZ320AP0xx
2. Upgrade to the latest software version. Refer to Technical Bulletin 08TV025 for the upgrade procedure and
TT commands. Refer to TB 08TV038 for the latest software package and the precise NVM file to be used.
2 / 2 09TV088R1
ADDITIONAL STEP WHEN CHANGING FROM ORIGINAL TO VE PANEL OR 32V SERVICE PANEL
3. The Inverter Harness needs to be replaced. For the 26” model, additionally a new LVDS Harness is needed.
Panel Type Inverter Harness LVDS Harness
26V4xx0 - Original 1-910-046-12 1-966-065-11
26V4xx0 - VE 1-910-049-33 1-835-838-11
32V4xx0 - Original 1-910-045-38
32V4xx0 - VE / Service 1-910-049-35
37V4xx0 - Original 1-910-046-13
37V4xx0 - VE 1-910-049-34
