Автор Тема: 09TV087  (Прочитано 193 раз)
09TV087
« : 01 Декабря 2023, 23:27:37 »
09TV087
KDL-32W4000, KDL-32W4210, KDL-32W4220, KDL-32W4230,
KDL-40W4000, KDL-40W4210, KDL-40W4220, KDL-40W4230,
KDL-46W4000, KDL-46W4210, KDL-46W4220, KDL-46W4230
BC
Subject IRIS
Caution when Replacing EG-1L Panel – W Series
A new panel type (VE) has been introduced, being incompatible to the original one.
• Always order the same panel as the one used in the set.
• However, if the original panel is out of stock, order a VE panel instead. For compatibility reasons, also the
Inverter Harness or IP5 board must be replaced in that case, and an EMI countermeasure must be applied.
1. Identify the panel type by the TV serial number and/or panel label.
Model
TV serial number Panel part number + label
Original panel VE panel Original panel VE panel
32W4000
3000001~3090001 3100001~3190001
1-802-648-11
1-802-648-12
xLTY320HA01-xxxx
1-802-801-11
xLTY320HA02-001x
4000001~4003501 4100001~4190001
4300001~4327559 4400001~4490001
4600001~4605972 4700001~4790001
9000001~9090001 9100001~9190001
9300001~9390001 9400001~9490001
9600001~9690001 9700001~9790001
32W4210
32W4220
/ 4400001~4490001
32W4230 9300001~9300001 9400001~9490001
40W4000
3000001~3090001 3100001~3190001 1-802-664-11
1-802-664-12
1-802-664-13
xLTY400HA05-xxxx
1-802-796-11
XLTY400HA10-001x
4000001~4090001 4100001~4190001
4300001~4390001 4400001~4490001
4600001~4690001 4700001~4790001
40W42x0 4300001~4390001 4400001~4490001
46W4000
3000001~3090001 3100001~3190001 1-802-663-11
1-802-663-12
1-802-663-13
1-802-663-14
XLTY460HB02-xxxx
1-802-795-11
xLTY460HB09-001x
46W42x0 4300001~4390001 4400001~4490001
2 / 6 09TV087
2. Upgrade to the latest software version. Refer to Technical Bulletin 08TV025 for the upgrade procedure and
TT commands. Refer to TB 08TV038 for the latest software package and the precise NVM file to be used.
TWO ADDITIONAL STEPS WHEN CHANGING FROM ORIGINAL TO VE PANEL
3. Depending on the model, the Inverter Harness or IP5 board needs to be replaced.
Panel type Inverter Harness IP5 (Complete kit)
32W4xx0 - Original 1-910-045-37
32W4xx0 - VE 1-910-049-35
40W4xx0 - Original / A-1548-233-B
40W4xx0 - VE / A-1556-762-A
46W4xx0 - Original / A-1548-234-B
46W4xx0 - VE / A-1556-763-A
4. Finish by applying an EMI countermeasure, adding the parts indicated below (2 times each).
Panel type Description Part number Description Part number
32W4xx0 Spring Panel 2-661-171-01 Sheet Core A 4-118-465-01
40W4xx0
46W4xx0 Spring Panel 2-661-171-01 Sheet Core C 4-000-896-01
