Автор Тема: 09TV086R1  (Прочитано 196 раз)
09TV086R1
« : 01 Декабря 2023, 23:26:03 »
09TV086R1
KDL-40V5500, KDL-40V5610, KDL-40V5800, KDL-40V5810 BC
Subject IRIS
Caution when Replacing Power Supply [REVISION 1]
Two types of Power Supply exist for the 40 inch models of the EX-2L_Coriander(_Sat) chassis. When replacing,
always try to order the same type as the one used in the set.
For compatibility reasons, never combine an old Power Supply (IP1(-F) Compl Kit)) with a new Harness Assy (Main
Connector cable) or vice versa. Refer to the table below to see which TV panels are equipped with which Power
Supply. The pictures on the next page allow differentiating visually between old and new parts.
ORIGINAL
IP1 Compl Kit (A-1660-720-A)
Harness Assy (1-910-054-61)
NEW
IP1-F Compl Kit (A-1708-948-A)
Harness Assy (1-910-059-40)
Model Old Panel S/N New Panel S/N Old Panel S/N New Panel S/N
KDL-40V5500
4300001~4316844 / / 4409828~4416443
4400001~4409827 / / /
9001662~9004991 9100011~9102350 9005612~ 9102351~
9307743~9318402 9400011~9406818 9319393~ 9406819~
9605922~9615611 9700012~9718399 9616560~ 9718400~
9900211~9902100 9910071~9911970 9902301~ 9911971~
KDL-40V5610
4300001~4301649 / / 4301650~4390001
/ / / 4400001~4401318
9300012~9302170 9400011~9401701 9303016~ 9401702~
9601411~9603391 9700011~9703016 9604032~ 9703017~
9900023~9900700 9910011~9911332 / /
KDL-40V5800
/ 9100011~9100020 / /
/ 9400011~9400526 / 9400527~
KDL-40V5810
/ 9100011~9100019 / 9100020~
/ 9400011~9400015
