Автор Тема: 09TV077  (Прочитано 194 раз)
09TV077
« : 01 Декабря 2023, 22:57:43 »
09TV077
KDL-52Z5500 BC
Subject IRIS
Preventive Panel Replacement 1386
No symptom or a vertical line.
In case of a TV repair or in case of problems with the panel,
the panel must be replaced (because defective) if it is in
the serial number list below.
Description Part number
LCD Panel (52 FHD 3TFT) 1-802-895-12
Model S/N Panel S/N Model S/N Panel S/N Model S/N Panel S/N
9301559 8Z9E0L110A 9302066 8Z9E0L6Q0B 9302127 8Z9E0I2N0E
9301560 8Z9E0LCM0B 9302067 8Z9E0L3B0A 9302128 8Z9E0L380E
9301561 8Z9E0I0R0F 9302068 8Z9E0L040F 9302129 8Z9E0L5M0A
9301562 8Z9E0I300A 9302069 8Z9E0LDC0F 9302130 8Z9E0L4B0A
9301563 8Z9E0I760F 9302073 8Z9E0L9V0B 9302132 8Z9E0L2M0B
9301564 8Z9E0L9G0B 9302074 8Z9E0L7T0B 9302145 8Z9E0LCD0A
9301565 8Z9E0LBT0A 9302075 8Z9E0L9V0A 9302146 8Z9E0L120D
9301570 8Z9E0I3L0E 9302076 8Z9E0LBP0F 9302147 8Z9E0L3J0D
9301572 8Z9E0L1C0D 9302077 8Z9E0L2F0E 9302148 8Z9E0LAH0E
9301573 8Z9E0I4I0F 9302078 8Z9E0L1T0C 9302149 8Z9E0L9A0C
9301574 8Z9E0LBV0B 9302103 8Z9E0LCW0D 9302150 8Z9E0L9W0D
9301666 8Z9E0LAS0B 9302104 8Z9E0L2T0A 9302151 8Z9E0LAH0F
9301668 8Z9E0L9Q0D 9302105 8Z9E0L0G0D 9302152 8Z9E0L940F
9301669 8Z9E0LDR0F 9302106 8Z9E0LB60D 9302160 8Z9E0LBJ0C
9301671 8Z9E0L100D 9302107 8Z9E0LCL0C 9302161 8Z9E0I4X0C
9301696 8Z9E0L7Q0C 9302108 8Z9E0LC40A 9302170 8Z9E0I200F
9301697 8Z9E0L9B0F 9302109 8Z9E084N0B 9302171 8Z9E08550C
9301698 8Z9E0LAJ0E 9302112 8Z9E0L390B 9302173 8Z9E0L4B0D
9301699 8Z9E0L0V0D 9302113 8Z9E0L640A 9302193 8Z9E0I7U0E
9301852 8Z9E0L8M0A 9302114 8Z9E0I440B 9302194 8Z9E0I8L0F
9301855 8Z9E0L240E 9302115 8Z9E0E0R0E 9302195 8Z9E0L4F0E
9301864 8Z9E0K6P0C 9302120 8Z9E0I300B 9302196 8Z9E0LAC0B
9301865 8Z9E0L4F0D 9302121 8Z9E0L640B 9302197 8Z9E0L2N0D
9302046 8Z9E0L4G0B 9302122 8Z9E0I4V0A 9302199 8Z9E0L3L0F
9302051 8Z9E0LC80F 9302123 8Z9E0L240A
