Автор Тема: 09TV070  (Прочитано 218 раз)
09TV070
« : 01 Декабря 2023, 22:51:33 »
09TV070
FL-1E Chassis BC
Subject IRIS
USB Input Malfunction 1781
The USB input may be defective, or it may fail to recognize any device.
To confirm whether this behaviour is due a specific location setting, repeat the initial TV set-up. Be sure to select
“Home” under the “Location” option, following the instructions below.
1. Press [HOME] on the remote commander. The TV Home menu appears on the screen.
2. Press [􀃍/􀃎] to select the category: “Settings”.
3. Press [􀃏/􀃐] to select the item: “Set-up”. Then press . Select “Auto Start-up” to restart the initial set-up.
