Автор Тема: 09TV064R4  (Прочитано 205 раз)
09TV064R4
« : 01 Декабря 2023, 22:48:30 »
09TV064R4
KDL-32V5500, KDL-32V5610, KDL-40V5500, KDL-40V5610,
KDL-46V5500, KDL-46V5610, KDL-52V5500, KDL-52V5610
BC
Subject IRIS
Caution when Replacing EX-2L_Coriander Panel [REVISION 4]
A new panel type (VA) has been introduced, being incompatible to the current one.
When replacing the panel, make sure to use compatible parts only, following the 4 steps below.
1. Identify the panel type in the table below.
Model
Serial number Part number
Existing panel New VA panel Existing panel New VA panel
KDL-32V5500
4300001~4332077 4400001~
1-802-801-11 1-802-931-21
9000001~9025327 9100001~
9300001~9354785 9400001~
9600001~9632882 9700001~
9900001~9906046 9910001~
KDL-32V5610
4300001~4303690 4400001~
9300001~9305845 9400001~
9600001~9606350 9700001~
9900001~9901965 9910001~
KDL-40V5500
4300001~4316844
4409828~
1-802-799-22
1-802-800-11 1-802-930-21
4400001~4409827
9000001~9005891 9100001~
9300001~9320802 9400001~
9600001~9622362 9700001~
9900001~9902100 9910001~
KDL-40V5610
4300001~4301649
4301650~
4400001~
9300001~9303100 9400001~
9600001~9604731 9700001~
9900001~9900700 9910001~
KDL-46V5500
4300001~4304572 4400001~
1-802-798-11 1-802-929-21
9000001~9001415 9100001~
9300001~9313754 9400001~
9600001~9606479 9700001~
9900001~9900432 9910001~
KDL-46V5610
4300001~4300460 4400001~
9300001~9301235 9400001~
9600001~9601334 9700001~
9900001~9900772 9910001~
2 / 4 09TV064R4
Model
KDL-52V5500
9000001~ 9100001~ 1-802-651-15
1-802-933-11
9300001~9310902 9400001~ 1-802-651-15
9310903~9310909 9400001~ 1-802-651-12
9310910~9310911 9400001~ 1-802-651-15
9310912~9310913 9400001~ 1-802-651-12
9310914~9315623 9400001~ 1-802-651-15
9315624~9315752 9400001~ 1-802-651-12
9315753~9316000 9400001~ 1-802-651-15
9316001~9316512 9400001~ 1-802-651-12
9316513~9316555 9400001~ 1-802-651-15
9316556~9316640 9400001~ 1-802-651-12
9316641~9316713 9400001~ 1-802-651-15
9316714~9316716 9400001~ 1-802-651-12
9316717~9316793 9400001~ 1-802-651-15
9316794~9317103 9400001~ 1-802-651-12
9317104~9324297 9400001~ 1-802-651-15
9600001~9603500 9700001~ 1-802-651-15
9603501~9603567 9700001~ 1-802-651-12
9603568~9604938 9700001~ 1-802-651-15
9900001~9900800 9910001~ 1-802-651-15
9900801~9900883 9910001~ 1-802-651-12
9900884~9901201 9910001~ 1-802-651-15
KDL-52V5610
9300001~9300723 9400001~
9600001~9600371 9700001~ 1-802-651-15
9900001~9900239 9910001~
2. Upgrade to the latest software version, referring to Technical Bulletin 09TV025 for the procedure and
TB 09TV040 for the latest software package and the precise NVM file to be used.
3. If needed, apply an EMI countermeasure, following the guidelines on the next pages.
4. For 46 inch models, verify whether the correct NVM file is used (VA panel = new NVM file).
COMPATIBLE PARTS LIST
Panel
Size / Type Label Panel P/N Spring P/N Sheet Core C P/N
32” Original LTY320HA02 1-802-801-11 2-682-457-01
(quantity: 2)
4-000-896-01
(quantity: 2)
32” VA LTY320HA03-A02 1-802-931-21 No need to use
40” Original
LTY400HA11-001 1-802-799-22
2-682-457-01
(quantity: 1)
4-000-896-01
LTZ400HA07-002 1-802-800-11 (quantity: 1)
40” VA LTY400HA12-A02 1-802-930-21
46” Original LTY460HB10-001 1-802-798-11 2-682-457-01
(quantity: 2)
4-000-896-01
46” VA LTY460HB11-A02 1-802-929-21 (quantity: 2)
52” Original
LTY[Z]520HB10-002 1-802-651-12
No need to use
LTY[Z]520HB10-108 1-802-651-15
52” VA LTY520HB11-001 1-802-933-11 2-661-200-01
(quantity: 2)
4-000-896-01
