Автор Тема: 09TV100R2  (Прочитано 379 раз)
09TV100R2
« : 01 Декабря 2023, 22:47:07 »
09TV100R2
KLV-32S550A BC
Subject IRIS
Caution when Replacing Panel [REVISION 2]
Three different types of panel (CMO, AUO and SLCD) exist, being not fully compatible.
• Depending on the original panel, additional parts exchanges may be needed together with a software update.
Replacement Panel
(Part number + Label)
Original Panel Label
SLCD NC
1-802-932-32 / -91
LTY320AP01
CMO (V315B3-L01) A
AUO VL (T315XW02VL) A
AUO VT (T315XW02VT) A
SLCD HC (LTZ320AA03) B
SLCD NC (LTY320AP01) OK
* A = LVDS Harness and Inverter Harness replacement + SW update
* B = Only SW update
* OK = No additional action needed
• In case a software update is required, use the applicable attachment to this document, referring to TB 10TV008
for the update procedure.
Panel type LVDS Harness Inverter Harness Attachment
CMO 1-836-565-11 1-910-053-24 TM3143_TD5160_CMO.C09
AUO VL 1-836-563-11 1-910-049-83 TM3143_TD5160_AUO08.C09
AUO VT 1-836-849-11 1-910-056-47 TM3143_TD5160_AUO09.C09
SLCD HC 1-836-847-11 1-910-053-52 TM3143_TD5160_SLCD08.C09
SLCD NC 1-836-847-11 1-910-053-52 TM3143_TD5160_SLCD09.C09
09TV100 - KLV-32S550A - Caution when Replacing Panel [REVISION 2]
