Автор Тема: 09TV092R1  (Прочитано 420 раз)
09TV092R1
« : 01 Декабря 2023, 22:43:04 »
09TV092R1
EX-2N_Peppermint Chassis, KDL-32P5600, KDL-32S5600,
KDL-37P5600, KDL-37S5600
BC
Subject IRIS
Macro Blocks Noise in Italian Broadcastings using SmartCAM [REVISION 1] 134B
1185
IMPORTANT
This Technical Bulletin has been released exclusively for problems with ITALIAN broadcasting services using
SmartCAM SD or HD MPEG2/MPEG4. No repair is needed for other broadcasters.
When the SmartCAM is connected to the TV, no matter whether the card is inserted in the CAM or not, macro
blocks may appear on the screen quite often, even on "Free to View" services.
1. On the Main Board, change resistor R7308 to the part indicated below.
Description Part number
OLD RES, Chip 150 / 1/16W + or -5% 1-218-943-11
NEW RES, Chip 22 / 1/16W + or -5% 1-218-933-11
2. Upgrade the software to the latest version, referring to the table on the next page for the applicable models and
software files.
Condition
code
Symptom
code
Part
number Ref. Section
code PWB Defect
code
Repair
code Qty.
Preventive 1 185 1-218-933-81 R7308 PCC B Y A 1
Remedying 1 34B 1-218-933-81 R7308 PCC B Y P 1
2 / 2 09TV092R1
Model Serial Number Remark
KDL-37P5500 4300001~4305613
Software => TB 09TV044
Procedure => TB 09TV043
KDL-37S5500 4300001~4325807
KDL-40P5500
4300001~4310670
9300001~9303662
KDL-40S5500
4300001~4326202
9300001~9301810
KDL-32P5600
4300001~4300101
Software => TB 09TV066
Procedure => TB 09TV065
9300001~9322266
KDL-32S5600
4300001~4317230
9300001~9332715
KDL-37P5600 4300001~4300775
KDL-37S5600 4300001~4312398
09TV092 - EX2N_Peppermint - Macro Blocks Noise in Italian Broadcastings using SmartCAM [REVISION 1]
