Автор Тема: 09TV061  (Прочитано 228 раз)
09TV061
« : 01 Декабря 2023, 22:38:46 »
09TV061
All AUO Models BC
Subject IRIS
AUO Panel Specs for Pixel Problem 1385
This document contains the criteria for determining pixel problems with AUO LCD panels.
1. INSPECTION CONDITIONS
• Ambient condition
* Temperature: 25 ± 5 °C
* Illumination: 300~700 lux
• Viewing distance
* 100 ± 5 cm from the LCD module
=> If the defect is only visible from within this distance, then do not consider it as a problem.
• Viewing angle
* 90 degrees (± 30° left / right / up / down) between module surface and the inspector’s line of view
• Test pattern and area
* Red, Green, Blue, White, Black, 25 % Grey, 30 % Grey, 50 % Grey
2. DOT DEFINITION
One pixel is the combination of three dots
