Автор Тема: 09TV082R10  (Прочитано 379 раз)
09TV082R10
« : 01 Декабря 2023, 20:50:26 »
09TV082R10
EX-2N_Peppermint_AVC_SPOT Chassis BC
Subject IRIS
Software Packages Follow-Up for EX-2N_Peppermint_AVC_SPOT Chassis [REVISION 10]
The latest software package #27 is valid for all models of the “EX-2N_Peppermint_AVC_SPOT” chassis.
Amongst others, it can be used to solve the problems below.
Issue IRIS code Rev.
Blocked TV – Symptom 1
* The TV may not respond anymore to the remote commander or any key button. 111F R0
ASU restores channel sorting to original
* When the set has no digital channels stored (only analogue) and it goes in standby
after powering on, the channel sorting is restored to original.
1727 R1
HD Service Macro Blocking
* While watching DVB-T services in High definition, the picture shows block noise. 134A R1
Picture pink tendency in standard mode
* Picture has a tendency to pink when Picture is set to “Standard” and Colour Tone to “Neutral”. 1422 R1
During Auto tuning, the TV crashes on Channel 24 in Siena due to an illegal TS signal
* As of version 21, the software is more robust against any future bad signalling
from this and other broadcasters.
1262 R3
Blocked TV – Symptom 2
* During the analog switch-off of several broadcasters in Italy the TV gets blocked
when tuning a certain channel.
C11A R5
TXT subpages - only 6 pages displayed
* When more than 6 sub pages are available, only the first pages can be seen/selected. 1286 R5
Station memory lost after unplugging AC
* When disconnecting the set from the mains (AC off) and then switching the TV on again
a few times, the list of analog and digital programs is lost.
P178 R5
Switch Off/On intermittently within the day (Spain)
* Set switches off with red and green LED lit. After a few seconds the set switches back on. 211D R5
Latched TV when zapping through RAI services (Italy)
* Image and audio disappear when zapping to or through RAI services. C11A R6
TV switches off and automatically restarts after 30 seconds (Iceland) 311D R6
Intermittent switch OFF-ON with TDT Premium card inserted
* With the TDT Premium card inserted, picture from the new service does not appear, while both
LEDs (red and green) are ON. Next, the TV switches OFF. After a few seconds a relay click is
heard and the TV powers ON normally.
F722 R6
Picture width constantly changes while viewing RTE1 (LCN001) (Ireland) C336 R7
TV blocks and reboots when zapping to R1 MUX (North of France) U722 R7
No or noisy sound after power on
* After putting the TV in standby or powering off for a minute, the sound is noisy or completely
missing after starting the TV.
1540 R8
Subtitles on ARTE HD (DVB-T service) are not displayed (France) D732 R8
09TV082 - Software Packages Follow-Up for EX-2N_Peppermint_AVC_SPOT Chassis [REVISION 10]
