Автор Тема: 09TV045  (Прочитано 230 раз)
09TV045
« : 01 Декабря 2023, 03:44:11 »
09TV045
EX-2L_Coriander, EX-2L_Basil BC
Subject IRIS
Caution when Exchanging Speaker Cable
During early production, the speaker cable was incorrectly wired and therefore required a special bridge connector.
Depending on the model, choose between one of the two options below when exchanging the speaker cable.
• V5500, V56x0: supplied speaker harness is fitted with a special bridge cable. Do not remove it!
Model Part number
KDL-32V5500, KDL-32V56x0 1-910-055-75
KDL-37V5500, KDL-37V56x0 1-910-055-76
KDL-40V5500, KDL-40V56x0 1-910-055-77
KDL-46V5500, KDL-46V56x0 1-910-055-79
KDL-52V5500, KDL-52V56x0 1-910-055-81
• W5500, W57x0: replace to a new speaker harness without special bridge cable. In case a bridge cable has
currently been applied in the set, remove it.
Model Part number
KDL-32W5500, KDL-32W57x0 1-910-057-28
KDL-37W5500, KDL-37W57x0 1-910-057-30
KDL-40W5500, KDL-40W57x0 1-910-057-32
KDL-46W5500, KDL-46W57x0 1-910-057-34
NOTE: The harness connects the speakers and key button board to the BA board (Multi Harness):
BA (CN5503/7201) => HSN (CN401) => HL1A (CN301) => SWITCH UNIT => SPKs.
