Автор Тема: 09TV043R4  (Прочитано 180 раз)
09TV043R4
« : 01 Декабря 2023, 03:42:54 »
09TV043R4
EX-2N_Peppermint Chassis BC
Subject IRIS
Software / Board Upgrade Procedure for EX-2N_Peppermint Chassis [REVISION 4]
This Technical Bulletin describes the upgrading procedure for the EX-2N_Peppermint Chassis, using a USB stick.
Amongst others, an update is needed for software fixes or when exchanging the B board.
Description Part number
B Board A-1709-482-A
IMPORTANT
If updating from a software version lower than v4.135 (SW package M4R20), an additional upgrade is needed
using the "SoftwareUpgrader.upg” file, as described in procedure 2-1. If the current version is 4.135 or higher,
start with procedure 2-2.
Remarks
• After a software upgrade, a limited number of 37/40P5500 sets will be converted to S5500. This can be noticed
in the Service Menu, but not by the end user.
• In a limited number of 37P5500 sets, the Upgrade Menu will not be displayed properly (see picture below), but
nevertheless is fully operational. This symptom disappears after installing the latest M4Rxx version.
• In case of a board exchange, if the NVM model does not match with the panel size, the screen colour may be
abnormal. This will automatically be resolved after the board exchange process.
• The SW version is linked to the NVM version. Always make sure to use the latest version of both together. Do
not mix up different versions.
1. Preparation
1-1. Take an empty
