Автор Тема: 09TV033R1  (Прочитано 217 раз)
09TV033R1
« : 01 Декабря 2023, 03:38:15 »
09TV033R1
KLV-S23A10E, KLV-S26A10E, KLV-S32A10E, KLV-S40A10E BC
Subject IRIS
Loss of Tuning or Unstable Picture after Channel Change [REVISION 1] 6260
One of the following problems may rise.
• 1. Loss of picture stability after channel change.
• 2. Loss of picture stability after the set was switched on.
• 3. If using automatic tuning, it may be impossible to tune channels in analogue.
CAUSE
Defective tuner unit.
In case the symptom occurs, it is recommended to proceed as below.
1. Add capacitor 47 μF in C9574.
Description Part number
Capacitor 47uF 1-107-909-11
