Автор Тема: 09TV032  (Прочитано 222 раз)
09TV032
« : 01 Декабря 2023, 03:36:59 »
09TV032
EG-1W Chassis BC
Subject IRIS
Split Screen 2350
One of the following symptoms may appear.
• 1. Split screen (Double image)
• 2. 60 Hz format signal picture mute delay
• 3. Instantaneous stop of the AC line voltage
CAUSE
• 1. Interference to 5 GHz of Aruba
• 2. Format change timing NG of VCTP
• 3. Micom cannot reboot by short-detected signal at 0.4 sec AC shutdown
Install the latest software packages, as explained in Technical Bulletin 08TV078, using the files attached to
Technical Bulletin 09TV018.
APPLICABLE SERIAL NUMBERS
Model Destination NO update needed for serial numbers
