Автор Тема: 09TV021  (Прочитано 194 раз)
09TV021
« : 01 Декабря 2023, 03:29:20 »
09TV021
KDL-40W4500, KDL-40W4730, KDL-46W4500 BC
Subject IRIS
Caution when Updating Software
In one particular production lot, the NVM data of 40W4500/4730 and KDL-46W4500 have been accidentally
swapped (all other user information, such as the combi label or carton box is correct). This may cause the following
problems.
• To the user: He may detect a wrong inch size in the product information menu.
• To service: In case of a software upgrade, when inputting the correct MS software version linked to the correct
panel size, the main micro will ignore the MS due to a model name mismatching.
If the symptom occurs, proceed as outlined below.
1. If the serial number of the set is within the range below, apply the correct TT number.
Model Serial number Correct TT number
KDL-40W4500
4025357~4026060
4337280~4337280
4398520~4398520
4398546~4399121
4399377~4400230
4400721~4400762
TT25
KDL-40W4730 4312476~4312775
KDL-46W4500
4006655~4007078
4337020~4337889
4338172~4338339
TT26
2. Apply the new SW version via the normal MS update procedure.
3. Check the White Balance level in “Cool” condition, since the adjustment data will have been reset to default.
