Автор Тема: 09TV017  (Прочитано 187 раз)
09TV017
« : 01 Декабря 2023, 01:37:13 »
09TV017
KDL-40W4500, KDL-40W4710, KDL-40W4720, KDL-40W4730,
KDL-46W4500, KDL-46W4710, KDL-46W4720, KDL-46W4730,
KDL-52W4500, KDL-52W4710, KDL-52W4730
BC
Subject IRIS
White Mura 134C
• Under certain dark viewing conditions the setting may cause the screen to exhibit a slight uneven uniformity
(White Mura / TV Clouding), especially when the screen is blank without video source. In the example below
the setting is AV input without signal.
• The symptom is not normally visible under typical viewing conditions such as watching movies or television
programmes.
• To achieve a high level of performance and picture clarity, Sony utilizes a very bright backlight setting. This
helps deliver the brightest picture possible, as well as exceptional picture clarity even with the darkest image
sources.
• In order to minimize the symptom described, it is recommended to adjust the TV settings to the below
condition.
* Settings => Set-up => Light Sensor: ON
* Settings => Set-up => Power Saving: Low or High
* Settings => Picture => Reduce Backlight Level to “Standard” or “Cinema mode” (Factory Setting = “MAX”)
