Автор Тема: 09TV055R1  (Прочитано 389 раз)
09TV055R1
« : 01 Декабря 2023, 00:29:31 »
09TV055R1
EG-1L Chassis BC
Subject IRIS
Bravia Theatre Sync Operation (CEC Improvement) [REVISION 1] K179
2716
Software package #410 is valid for the EG-1L chassis, and can be used in case of intermittent Bravia Theatre Sync
Operation problems (CEC Improvement).
Issue IRIS code
Incorrect TV operation with the Sony Cinema Surround System
* When taking the TV out of standby and then switching it to theatre mode, the audio system does
not power on, and the TV theatre function locks up.
K179
After OAD, CEC operation is not available 2716
IMPORTANT: Only use software package #410 to remedy the above problems. Refer to TB 08TV038 for regular
updates.
Install software package #410 as explained in Technical Bulletin 08TV025, using the zip file(s) indicated in the table
below and attached to this Technical Bulletin, depending on the model type.
Date Software
package Models Attachment Files
November
2009 #410
HD
Ready eg1l_aep_osim_pkg_410_noosim_memorystick.zip VCTP micro: TM4.10
Verd Micro: S1.130E
Full HD eg1l_aep_osim_pkg_410_memorystick.zip Digital Micro: DM2.19.408
09TV055 - EG-1L - Bravia Theatre Sync Operation (CEC Improvement) [REVISION 1]
