Автор Тема: 09TV053R2  (Прочитано 365 раз)
09TV053R2
« : 01 Декабря 2023, 00:27:41 »
09TV053R2
EX-2N_Peppermint_AVC_DVBC, EX-2N_Peppermint_AVC_SPOT,
EX-2N_Peppermint_AVC_WXGA Chassis
TD
Subject IRIS
EDID Writing Support [REVISION 2] 1310
1786
No recognition of the panel specification via HDMI connection or D-Sub 15 connection. As a result, no picture may
appear, or the screen may be in lowest screen resolution.
CAUSE
Empty EDID NVM.
Follow the instructions below to write the EDID NVM data, using the files attached to this Technical Bulletin. The
method depends on the input device.
Model EDID PC Input EDID HDMI Input 1 – 2 – 3
P/S3600 ex2n_AVC_SPOT_pcin.all
ex2n_CH1_hdmi_full_PC_50_60_24_25_30_1080P_AC3_draft6.eep
ex2n_CH1_hdmi_full_PC_50_60_24_25_30_1080P_AC3_draft6_CEC.eep
P/S5500 ex2n_pcin.all
ex2n_hdmi_full_PC_50_60_24_25_30_1080P_LS.eep
ex2n_hdmi_full_PC_50_60_24_25_30_1080P_LS_CEC.eep
P3550
P/S5550 ex2n_AVC_DVBC_WXGA_pcin.all
ex2n_CH1_hdmi_wxga_PC_50_60_24_25_30_1080P_AC3_draft8.eep
ex2n_CH1_hdmi_wxga_PC_50_60_24_25_30_1080P_AC3_draft8_CEC.eep
P/S5600 ex2n_AVC_nonDVBC_pcin.all
P/S5650 ex2n_AVC_DVBC_FHD_pcin.all
19S57xx ex2n_AVC_DVBC_WXGA_pcin.all
ex2n_hdmi_2_inputs_wxga_AC3.eep
ex2n_hdmi_2_inputs_wxga_AC3_CEC.eep
1. Data handling between TV, I2C device and NVM for PC INPUT via TRACE
1-1. Open the Assist menu. Under [Local] select [Trace – Direct memory].
09TV053 - EX-2N - EDID Writing Support [REVISION 2]
