Автор Тема: 09TV052R3  (Прочитано 447 раз)
09TV052R3
« : 01 Декабря 2023, 00:25:44 »
09TV052R3
EX-2N_Clove, EX-2N_Peppermint, EX-2N_Peppermint_AVC,
EX-2N_Peppermint_AVC_DVBC, EX-2N_Peppermint_AVC_SPOT,
EX-2N_Peppermint_AVC_WXGA Chassis
TD
Subject IRIS
Serial Number Writing Support [REVISION 3] 1721
No serial number after board exchange.
CAUSE
Generic serial number for service.
Write the applicable serial number to the NVM using the TL3 jig. The serial number address in the NVM consists
of 4 bytes in hexadecimal format.
1. Apply “TT31”.
2. Extract the zip file attached to this Technical Bulletin, and run the "Code2.exe" file.
Date Attachment File
May 2009 Code2_EX2N.zip Code2.exe
3. Make sure that the COM port baud rate is set to 115200.
4. In the main menu, open the "Analyzer" window: [TOOLS] => [ANALYZER].
5. Check the [Add Check Sum] box.
6. Refer to the info on the next page to determine the hexadecimal code.
7. Enter the converted code (for example “F3 00 11 01 00 00 00 00 00 00 1D EA 01 09 3D 00”) in the
[Send Command] box to write the serial number, and press [SEND].
8. Apply “TT08”.
9. In the User menu, verify whether all information has been updated correctly.
09TV052 - EX-2N - Serial Number Writing Support [REVISION 3]
