Автор Тема: 09TV029R4  (Прочитано 429 раз)
09TV029R4
« : 01 Декабря 2023, 00:15:49 »
09TV029R4
EX-2L_Basil, EX-2L_Basil_Sat, EX-2L_Coriander, EX-2L_Coriander_Sat,
EX-2L_Ginger, EX-2L_Eco_Basil, EX-2L_Paprika,
EX-2L_Paprika_Sat Chassis
TD
Subject IRIS
EDID Writing Support [REVISION 4] 1310
1786
No recognition of the panel specification via HDMI connection or D-Sub 15 connection. As a result, no picture may
appear, or the screen may be in lowest screen resolution.
CAUSE
Empty EDID NVM.
Follow the instructions below to write the EDID NVM data, using the files attached to this Technical Bulletin. The
method depends on the input device.
Model EDID PC EDID HDMI Input A – B – C – D
KDL-22E53xx pcin_ex2l_wxga.all ex2l_hdmi_edid_0010_aep_wxga_4term.eep
EX-2L_Paprika(_Sat) pcin_ex2l_coriander.all ex2l_hdmi_edid_0010_aep_wcg_4term.eep
ALL OTHER pcin_ex2l_coriander.all ex2l_hdmi_edid_0010_aep_fhd_4term.eep
1. Data handling between TV, I2C device and NVM via TRACE for PC INPUT
NOTE: Send the appropriate ECS command, and select [Add Check Sum] in order to disable the write protection.
Check Technical Bulletin 09TV028 for the procedure.
Model ECS Command
KDL-22E53xx, EX-2L_Coriander(_Sat) F1 00 0B 02 42 01 00 07 00 11
KDL-32/40E55xx, EX-2L_Basil(_Sat),
EX-2L_Eco_Basil, EX-2L_Paprika(_Sat) F1 00 0B 02 42 01 00 07 00 93
1-1. Open the Assist menu. Under [Local] select [Trace – Direct memory].
1-2. By double-clicking the tab, a new window will pop up, listing all possible NVM types handled by TRACE.
09TV029R4 - EX-2L - EDID Writing Support [REVISION 4]
