Автор Тема: 09TV020R4  (Прочитано 323 раз)
09TV020R4
« : 30 Ноября 2023, 23:34:55 »
09TV020R4
FL-1E Chassis BC
Subject IRIS
Software Packages Follow-Up for FL-1E Chassis [REVISION 4]
The latest software package (v.210) is valid for all FL-1E chassis models, and solves the problems below.
Issue IRIS code
Horizontal lines on the screen, as in the example below.
1386
DVB-T issue (Denmark): TV2 always stored in channel space nr. 4.
* TV2 channel region at room no. 4 is not the same as before the change.
* TV2 located in multiple channel locations, but cannot be displayed.
1727
• Download and install the zip file attached to this document, referring to TB 09TV019 for the update procedure.
• Even if case none of the above mentioned symptoms is reported, it is recommended to update a set in any
repair case as a preventive action.
Date Attachment Micros Version
November 2009 FL1E_MS_pkg_adj_mask_210.zip
Digital Micro (DM) SW 2.28.207 - Boot 0.76.27
TV Micro (TM) SW 1.008 - Boot 1.000 - NVM 1.006
STBY Micro (VM) SW 1.003 - Boot 1.000 - NVM 1.004
Panel Micro (PM) SW 1.002 - Boot 1.000 - NVM 1.002
FRC-M FW 1.41 - ROM 9
09TV020 - Software Packages Follow-Up for FL-1E Chassis [REVISION 4]
