Автор Тема: 09HA001  (Прочитано 213 раз)
09HA001
« : 30 Ноября 2023, 23:21:45 »
09HA001
TAV-L1 AU
Subject IRIS
Scratched “Cover Assy, Front” 116E
The centre of the “Cover Assy, Front” may become scratched.
CAUSE
Deformed Guide Assy, due to improper transportation of the set.
WARNING: Do not hold the DVD block when moving or carrying the set.
2 / 4 09HA001
If the damage to the “Plate(F/C)” is only cosmetic, replace the aluminium panel of the “Cover Front, Assy”, following
the procedure outlined below.
Description Part number
Plate F/C 2-650-808-01
NOTE: Neither the “Cover Front, Assy” (X-2109-018-1) as a whole, nor the plastic frame of the “Cover Front, Assy”
are available as service part.
1. Replacement of aluminium panel
1-1. Raise the 6 claws indicated in the picture vertically.
1-
