Автор Тема: 08TV092R3  (Прочитано 207 раз)
08TV092R3
« : 30 Ноября 2023, 22:50:28 »
08TV092R3
KDL-32S4000, KDL-32S4010, KDL-32U4000, KDL-32V4000,
KDL-32V4200, KDL-32V4210, KDL-32V4220, KDL-32V4230,
KDL-32V4240
NT
Subject IRIS
Caution when Exchanging 32” Panel [REVISION 3]
A new panel (Sharp) has been introduced for the SE-2AG chassis 32” model, replacing the original SEC panel.
If replacing, use the same type of panel. However, if this is not possible, proceed as indicated below. Refer to the
table below to verify the panel type installed.
Model Type Serial number
KDL-32S4000
KDL-32U4000
KDL-32V4000
SEC
9000001~
9300001~
9600001~
Sharp
9100001~
9400001~
9700001~
KDL-32V4200 Sharp
9100001~
9400001~
9700001~
KDL-32S4010
KDL-32V4210
KDL-32V4220
KDL-32V4230
KDL-32V4240
SEC 2000001~
9300001~
Sharp 2200001~
9400001~
1. Software update
Write the latest version of the software to the BC1 board, using the attachment to Technical Bulletin 08TV087, and
referring to Technical Bulletin 09TV016 for the procedure.
Description Part number
BC1 board A-1599-690-A
