Автор Тема: 08TV090  (Прочитано 207 раз)
08TV090
« : 30 Ноября 2023, 22:34:03 »
08TV090
NEX Chassis BC
Subject IRIS
Lip-sync Problem C57X
A Lip-sync problem may occur, especially when playing the “ITV1” channel (UK only).
CAUSE
Audio Description being a non-signal. When Audio Description and Main Audio are mixed, a time stamp will not be
set up correctly.
If the symptom occurs, upgrade to the latest software version, using the attachment to Technical Bulletin 08TV062.
