Автор Тема: 08TV070R1  (Прочитано 202 раз)
08TV070R1
« : 30 Ноября 2023, 06:13:54 »
08TV070R1
EG-1L, EG-1L_100Hz, EG-1L_200Hz, EG1LL Chassis TD
Subject IRIS
TL3 Jig Modification [REVISION 1]
To make the TL3 Jig work with EG1L and EG1LL models, a special flex cable is needed.
Choose one of the options below.
• Cable modification
Modify an existing flex cable by cutting the pins 4, 10 and 13 at TL3 side, as indicated in the picture below.
• Cable purchase
Purchase a “Modified TL3 Jig Cable” with the part number in the table below. A green marker has been attached to
the modified side of the cable. Connect this green side to the TL3 Jig.
Description Part number
TL3 Jig Cable Modified 9-948-600-17
