Автор Тема: 08TV063  (Прочитано 299 раз)
08TV063
« : 30 Ноября 2023, 01:08:22 »
08TV063
EG-1L100Hz Chassis TD
Subject IRIS
Software Upgrading Procedure EG-1L100Hz Chassis
This Technical Bulletin describes the software upgrading procedure for the EG-1L100Hz chassis when, amongst
others, exchanging the BGE board.
Follow the outlined procedure below for upgrading to the latest software version, using the attachment to Technical
Bulletin 08TV064.
1. Memory Stick Formatting
1-1. Take a Memory Stick of at least 16 MB (128 MB recommended).
1-2. Format the Memory Stick using a Memory Stick formatter. A special program can be downloaded from:
http://support.sony-europe.com/memstick/downloads/downloads_ms.asp?l=en&f=MSFRM#disc.
NOTE: Windows formatters are not supported.
2. Update of MS DL Digital, VCTP, NVM VCTP & Verd data
2-1. Unzip the update file “MSImage_EG1L_PKGxxxxEE_BCN_VC.zip” attached to Technical Bulletin 08TV064.
2-2. Copy the “polo_proto1” folder into the root of your MS.
2-3. Switch off the TV using the [Power] key. Do not use the [Standby] key on the remote commander!
2-4. Insert the Memory Stick.
2-5. Switch on the TV using the [Power] key.
2-6. The “Digital Micro” will be updated. No download message appears. Only the green LED is ON.
2-7. When finished, the VCTP, NVM VCTP & Verd update will start. An “UPDATE START” message appears. If the
update process does not start (no LEDs activity, see below note), go directly to “3. TT number application”.
NOTE: The “UPDATE START” message does not appear if first the Power menu is shown. In that case it is
necessary to monitor the LED activity.
=> If the amber LED blinks and the red LED is ON, this means that the update process has started.
=> If no LED activity after 3 minutes (except for green LED), this means the update has not started.
